Error bad provider ecuxml and other
Hi,
i looked at log.txt and found this error:
2nd errors:
[ERROR] 6/9/2012 3:12:02 PM.661[MILTrace] dataraw: 47 00 00 00 00 00 00
[ERROR] 6/9/2012 3:12:08 PM.148[MILTrace] dataraw: 43 00 00 00 00 00 00
[ERROR] 6/9/2012 3:17:07 PM.467[MILTrace] dataraw: 47 00 00 00 00 00 00
[ERROR] 6/9/2012 3:17:12 PM.162[MILTrace] dataraw: 43 00 00 00 00 00 00
[ERROR] 6/9/2012 3:22:08 PM.602[MILTrace] dataraw: 47 00 00 00 00 00 00
[ERROR] 6/9/2012 3:22:13 PM.796[MILTrace] dataraw: 43 00 00 00 00 00 00
What are this errors?
I have standalone hobdrive.
- Код: Выделить всё
[ERROR] 6/11/2012 8:54:34 PM.280[HOBD] bad provider ecuxml://\SDMMC\hobd\user.ecuxml
System.IO.FileNotFoundException: An error message is available for this exception but cannot be displayed because these messages are optional and are not currently installed on this device. Please install â€NETCFv35.Messages.EN.wm.cab’ for Windows Mobile 5.0 and above or â€NETCFv35.Messages.EN.cab’ for other platforms. Restart the application to see the message.
at #=q9tFs5SaxYE72sIkZujqBnBxswruuZP6G4AMKF0C9D2w=.#=qTC5R$BYcIogjz3tbF4JscU7JJ0DyJm2HVs8Tqd0s_po=(String #=qn0eZ6Bs$5wC5ZkQY4QUwKg==)
at #=q9tFs5SaxYE72sIkZujqBnBxswruuZP6G4AMKF0C9D2w=.#=qOccS46tintUxczkNDY9JlQ==()
at #=q9tFs5SaxYE72sIkZujqBnBxswruuZP6G4AMKF0C9D2w=.#=qMr9sLILk2sNamiZPLKrV4w==()
at #=q7nHutiQM2q96L12Nx9lBWw==.#=qVnV54QUf42vgXVEG0BKSkw==()
at #=qNNmINzG_Gav7Gc77LwIiDw2gnDNe5Gn5QQfEyHHBp_g=.#=q3GEWFXnt2A_c2SqWhntMxA==(String[] #=qnqEvJLJodo6kl$ZM3boudQ==)
2nd errors:
Re: Error bad provider ecuxml and other
maxman, thats a normal functioning, just an extra tracing.
then i ignore this
thank you for quick answer
