Standalone Mips ii Version
Good day Cail, I am having some problems getting hobdrive to work as a standalone mips version. The problem is when I copied all the dotnet files (Mips ii version) that I can find I get the following error. here is a picture of the error I get. http://i52.tinypic.com/oiu6ud.jpg Is there anyway that you or someone can create a standalone mips version of your hobdrive application because I am having no luck at all with this ha ha.
Any help would be really appreciated.
Thank you very much
Thank you very much
Re: Standalone Mips ii Version
Can you make sure you don't have file hobd.exe.config in standalone folder?
OK thank you I will remove the hobd.exe.config file from the standalone folder if it exists. I will try that and let you know.
Thank you
Thank you
Hi Cail, I checked to make sure that hobd.exe.config was not in the folder. It was so I deleted it and tried it again. When I clicked on HOBD I still get the same error message. Do you have anymore ideas ?
Thank you
Thank you
sorry no. probably some files are missing. trying to find a mips device to resolve this. will notify you for sure.
