In car gps/dvd
In car gps/dvd
Hi Just wondering if you software will work on the following unit;
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=370594078193#ht_14075wt_1140
what sort of connector would you recommend usb or bluetooth and if so are any in particular more suited to your software?
regards,
steve
regards,
steve
Re: In car gps/dvd
Hi Steve,
It will, but you'll have to solder an external USB-host connector to it. Read the appropriate thread on this topic.
There could be a chance such a connector already exist on this unit (in that case it is normally referenced as "3G modem ready"). But from information above I have not found any references of it.
Both BT and USB ELM adapters will work fine as soon as you'll get a USB-host connector
