HOBD 1.1.57 Wince Not showing up Instant fuel economy
Hi Cali,
It has been some time i am back with you. I saw your new beta release 1.1.55 and installed it on my win ce 6.0 embedded multimedia device and connected with my tata nano cx 2010.
It has MAP sensor and I set it as all parameters same as what i had earlier set up for 1.1.27. Now it is showing all of the values on trip computer screen but for Instant fuel economy.
I am attaching the log file and vehicle file for your reference. I just want to know if it is something to do with configuration or it is not a feature available anymore on hobd.
Thanks in advance for your co-operation and reply.
Thanks,
sundar
user.vehicles File contents
<vehicles>
<vehicle id="My nano" name="My nano" make="Common" title="OBD-II" year="2010" details="nano cx">
<obd>
<engine-init>ATSP0</engine-init>
<sensors>hobd.MAPSensors</sensors>
</obd>
<liters>0.6328</liters>
<stoich>14.7</stoich>
<volumetric-efficiency>95</volumetric-efficiency>
<idle-speed>1100</idle-speed>
<warm-engine-level>80</warm-engine-level>
<trip-interval>800</trip-interval>
<weight>650</weight>
<tank>17.0</tank>
</vehicle>
</vehicles>
Thanks,
sundar
<vehicles>
<obd>
</obd>
<tank>17.0</tank>
</vehicle>
</vehicles>
- This is the log file that i setup and tested. so it contains all ops. performed.
Re: HOBD 1.1.57 Wince Not showing up Instant fuel economy
Hi.
You've settled up
idle-speed to 1100 km!
this means hobdrive treats your vehicle as "not moving" if it runs slower than 1100 km.
Just put this to default, or to any meaningful value (4-7) and everything will be ok.
You've settled up
Hi Cail,
Thanks a lot for your help i just set it blank and it keeps working now as before. Hats off to you and hobd/hobdrive!!
Thanks,
sundar
Thanks,
sundar
