Text on screen
Text on screen
stucroft7 » 22 мар 2013, 15:21
This is the text I get on boot up of the program on my wince5 head unit
pics attached
Re: Text on screen
cail » 25 мар 2013, 14:57
I see the main screen (partial). Does it appears fullscreen after clicking OK?
Or it remains "small"?
Re: Text on screen
stucroft7 » 28 мар 2013, 18:40
Hi yes it goes to full screen after clicking need to get this resolved as I would like to purchase full system
Re: Text on screen
stucroft7 » 01 апр 2013, 15:20
Hi Cail
I have the software working ok now but see no data in left hand bottom corner there is a green light but no data whats happening
Stu
Re: Text on screen
cail » 02 апр 2013, 12:32
Stu, what vehicle do you have? You probably should setup protocol correctly.
Re: Text on screen
stucroft7 » 02 апр 2013, 17:07
Hi Bmw x5 2003
Re: Text on screen
cail » 03 апр 2013, 12:58
Do you know any other software works with your vehicle via ELM327 adapter?
European vehicles at these years do not always supports OBD2 and ELM327 connections.
Re: Text on screen
stucroft7 » 03 апр 2013, 13:50
Hi unsure on the ELM adapter I have edibas acd carsoft working ?
Re: Text on screen
stucroft7 » 03 апр 2013, 21:43
Hi Cali
got the software working on laptop with the adapter all seems fine :) however there seems to be some differences in the wince software mainly the options in the vehicle config as they do not match whats available in the windows 1.1.1 32 software
Regards
Stu
Re: Text on screen
cail » 04 апр 2013, 11:06
Hi,
laptop and wince versions are absolutely equal in functions. Make sure you use the same version number (try also latest beta at viewtopic.php?f=2&t=63 )
You even can copy config files from laptop to wince and everything should connect fine.
Re: Text on screen
stucroft7 » 04 апр 2013, 20:44
Hi had trial version working on head unit so I purchased Hoddrive installed on my head unit with same parameters as trial version but cannot get it to work green light is on but no data I also just connect to my laptop with cable and trial software on laptop works perfect ??
Re: Text on screen
cail » 05 апр 2013, 11:31
Think you have some differences in setup.
Ultimately, just copy files config.xml and user.vehicles from working demo to installation folder of full version. This will inherit all settings and should work.
Re: Text on screen
stucroft7 » 05 апр 2013, 18:41
Hi Cail
all working OK is it possible to change KMH to MPH and keep deg c for temp
Stu
Re: Text on screen
cail » 08 апр 2013, 12:44
Within next releases we plan to introduce more flexible units configuration.
We have UK setup with celsius and miles (but it uses uk gallons).
