Yes Cail, I'm sure. I visualize the LEDs of the device in action during the commands sent by HOBDrive. I also tested with Torque Pro software (Android) and the result is the same, arriving just yet to talk to the ECU.
============TRACE
[INFO] 10/3/2014 21:21:03.002[HOBD] HOBD 1.1.1 24.02.2012 14:34
[INFO] 10/3/2014 21:21:03.187[HOBD] Env: 3.5.7283.0
[INFO] 10/3/2014 21:21:05.009[HOBD] SN: 00540054-0034-0058-0030-545434583042445F3000
[INFO] 10/3/2014 21:21:11.466[HOBD] Vehicle: My Vehicle
[TRACE] 10/3/2014 21:21:11.649[HOBD] RegisterProvider: hobd.OBD2Sensors
[INFO ] 10/3/2014 21:21:11.745[SpeedSensor] Using default coefficient
[TRACE] 10/3/2014 21:21:11.764[HOBD] RegisterProvider: ecuxml://ecu/obd2.ecuxml
[ERROR] 10/3/2014 21:21:11.826[HOBD] bad provider ecuxml://\Storage Card\Programas\HOBD1.1.1\ecu/obd2.ecuxml
System.Exception: unknown tag `command` while creating PID Lambda11
at hobd.ECUXMLSensorProvider.init(SensorRegistry registry)
at hobd.ECUXMLSensorProvider.Activate(SensorRegistry registry)
at hobd.SensorRegistry.RegisterProvider(SensorProvider provider)
at #=queSlQ6WOwqlLYH3QsyFJK3LG9wDtR6wuXiVTPMnBgSo=.#=qYbfmgSv9IK7nU8yg9itpObmzP2a8HTUFWGe0jLVvkvE=(String #=qCpA2yT9JmyyxP5CYdok8Cw==)
at #=queSlQ6WOwqlLYH3QsyFJK3LG9wDtR6wuXiVTPMnBgSo=.#=q4p1l7P2TL5YDzMbY2p0Dew==()
at #=queSlQ6WOwqlLYH3QsyFJK3LG9wDtR6wuXiVTPMnBgSo=.#=qNkRdgpRnBCG8_s7mBF4X6g==()
at #=qemyrhFzVjqMRdsGEWu$9lQ==.#=qrIZO76EQPMJEaiXgp3O51Q==()
at #=qsn5YiReJqOOgWguWkwcpkg==.#=qp$Y68N4sL$EWs2aDqswyWA==(String[] #=qM$ch0Osy81ygpZG0onoQ5g==)
[TRACE] 10/3/2014 21:21:11.871[HOBD] RegisterProvider: hobd.ELMSensors
[TRACE] 10/3/2014 21:21:11.883[HOBD] RegisterProvider: hobd.MAFSensors
[INFO ] 10/3/2014 21:21:11.895[LitersPerHourSensor] Using default stoich ratio
System.Collections.Generic.KeyNotFoundException: KeyNotFoundException
at System.ThrowHelper.ThrowKeyNotFoundException()
at System.Collections.Generic.Dictionary`2.get_Item(String key)
at hobd.elm.maf.LitersPerHourSensor.SetRegistry(SensorRegistry registry)
at hobd.SensorRegistry.Add(Sensor sensor)
at hobd.MAFSensors.Activate(SensorRegistry registry)
[TRACE] 10/3/2014 21:21:11.939[HOBD] RegisterProvider: hobd.CommonSensors
[TRACE] 10/3/2014 21:21:11.960[HOBD] RegisterProvider: ecuxml://ecu/default.ecuxml
[TRACE] 10/3/2014 21:21:11.981[HOBD] RegisterProvider: ecuxml://user.ecuxml
[ERROR] 10/3/2014 21:21:12.046[HOBD] bad provider ecuxml://\Storage Card\Programas\HOBD1.1.1\user.ecuxml
System.IO.FileNotFoundException: An error message is available for this exception but cannot be displayed because these messages are optional and are not currently installed on this device. Please install ‘NETCFv35.Messages.EN.wm.cab’ for Windows Mobile 5.0 and above or ‘NETCFv35.Messages.EN.cab’ for other platforms. Restart the application to see the message.
[TRACE] 10/3/2014 21:21:12.249[FCS] lph: MAF.LitersPerHour
[TRACE] 10/3/2014 21:21:12.267[FCS] lph: MAF.LitersPerHour
[TRACE] 10/3/2014 21:21:12.278[FCS] lph: MAF.LitersPerHour
[TRACE] 10/3/2014 21:21:12.569[HOBD] Connecting stream: btspp://000D18A04E35;pin=1234
[INFO] 10/3/2014 21:21:12.656[HOBD] system width: 800, height: 480
[INFO] 10/3/2014 21:21:12.666[HOBD] wa width: 800, wa height: 454
[TRACE] 10/3/2014 21:21:14.058[HomePage] tap distance 26
[INFO] 10/3/2014 21:21:14.183[HomePage] System DPI: 96
[INFO] 10/3/2014 21:21:14.199[HomePage] App DPI: 57
[INFO] 10/3/2014 21:21:14.212[HomePage] layout: 475x269
[INFO] 10/3/2014 21:21:14.224[HomePage] form: 242x293
[INFO ] 10/3/2014 21:21:16.279[HomePage] no layout file user.layout
[TRACE] 10/3/2014 21:21:17.382[OBD2Engine] -> INIT
[INFO ] 10/3/2014 21:21:17.584[OBD2Engine] Open btspp://000D18A04E35;pin=1234
[TRACE] 10/3/2014 21:21:19.248[BluetoothStream] Open 000D18A04E35 serviceid pin 1234
[TRACE] 10/3/2014 21:21:20.196[OBD2Engine] -> ATZ
[TRACE] 10/3/2014 21:21:20.254[OBD2Engine] SendCommand:ATZ
[TRACE] 10/3/2014 21:21:21.164[OBD2Engine] HandleReply: ?
ELM327 v1.5
[TRACE] 10/3/2014 21:21:21.173[OBD2Engine] SendCommand:ATZ
[TRACE] 10/3/2014 21:21:21.993[OBD2Engine] HandleReply: ATZ
ELM327 v1.5
[INFO] 10/3/2014 21:21:22.011[OBD2Engine] VersionInfo: ?ELM327 v1.5
[TRACE] 10/3/2014 21:21:22.020[OBD2Engine] -> ATE0
[TRACE] 10/3/2014 21:21:22.066[OBD2Engine] SendCommand:ATE0
[TRACE] 10/3/2014 21:21:22.128[OBD2Engine] HandleReply: ATE0
OK
[TRACE] 10/3/2014 21:21:22.138[OBD2Engine] -> ATL0
[TRACE] 10/3/2014 21:21:22.189[OBD2Engine] SendCommand:ATL0
[TRACE] 10/3/2014 21:21:22.251[OBD2Engine] HandleReply: OK
[TRACE] 10/3/2014 21:21:22.261[OBD2Engine] -> EXTRAINIT
[TRACE] 10/3/2014 21:21:22.346[OBD2Engine] SendCommand:ATSP 0
[TRACE] 10/3/2014 21:21:22.409[OBD2Engine] HandleReply: OK
[TRACE] 10/3/2014 21:21:22.419[OBD2Engine] -> EXTRAINIT
[TRACE] 10/3/2014 21:21:22.465[OBD2Engine] -> SENSOR_INIT
[TRACE] 10/3/2014 21:21:22.512[OBD2Engine] SendCommand:0100
[TRACE] 10/3/2014 21:21:26.767[OBD2Engine] HandleReply: SEARCHING...
UNABLE TO CONNECT
[ERROR] 10/3/2014 21:21:26.790[OBD2Engine] Critical error:SEARCHING...
UNABLE TO CONNECT
[TRACE] 10/3/2014 21:21:26.809[OBD2Engine] -> ERROR
[TRACE] 10/3/2014 21:21:48.061[OBD2Engine] -> INIT
[INFO ] 10/3/2014 21:21:48.527[OBD2Engine] Open btspp://000D18A04E35;pin=1234
[TRACE] 10/3/2014 21:21:49.158[BluetoothStream] Open 000D18A04E35 serviceid pin 1234
[INFO ] 10/3/2014 21:21:49.932[HOBD] app exit
============ERROR
[INFO] 10/3/2014 21:07:04.002[HOBD] HOBD 1.1.1 24.02.2012 14:34
[INFO] 10/3/2014 21:07:04.198[HOBD] Env: 3.5.7283.0
[INFO] 10/3/2014 21:07:05.986[HOBD] SN: 00540054-0034-0058-0030-545434583042445F3000
[INFO] 10/3/2014 21:07:06.360[HOBD] Vehicle: My Vehicle
[ERROR] 10/3/2014 21:07:06.556[HOBD] bad provider ecuxml://\Storage Card\Programas\HOBD1.1.1\ecu/obd2.ecuxml
[ERROR] 10/3/2014 21:07:06.617[HOBD] bad provider ecuxml://\Storage Card\Programas\HOBD1.1.1\user.ecuxml
[INFO] 10/3/2014 21:07:07.075[HOBD] system width: 800, height: 480
[INFO] 10/3/2014 21:07:07.094[HOBD] wa width: 800, wa height: 480
[INFO] 10/3/2014 21:07:08.656[HomePage] System DPI: 96
[INFO] 10/3/2014 21:07:08.672[HomePage] App DPI: 57
[INFO] 10/3/2014 21:07:08.681[HomePage] layout: 475x285
[INFO] 10/3/2014 21:07:08.692[HomePage] form: 242x293
[INFO] 10/3/2014 21:07:17.425[OBD2Engine] VersionInfo: ?ELM327 v1.5
[ERROR] 10/3/2014 21:07:22.093[OBD2Engine] Critical error:SEARCHING...
UNABLE TO CONNECT
==============DUMP
[INFO] 10/3/2014 21:23:48.001[HOBD] HOBD 1.1.1 24.02.2012 14:34
[INFO] 10/3/2014 21:23:48.185[HOBD] Env: 3.5.7283.0
[INFO] 10/3/2014 21:23:49.991[HOBD] SN: 00540054-0034-0058-0030-545434583042445F3000
[INFO] 10/3/2014 21:23:54.051[HOBD] Vehicle: My Vehicle
[TRACE] 10/3/2014 21:23:54.117[HOBD] RegisterProvider: hobd.OBD2Sensors
[INFO ] 10/3/2014 21:23:54.193[SpeedSensor] Using default coefficient
[TRACE] 10/3/2014 21:23:54.207[HOBD] RegisterProvider: ecuxml://ecu/obd2.ecuxml
[ERROR] 10/3/2014 21:23:54.267[HOBD] bad provider ecuxml://\Storage Card\Programas\HOBD1.1.1\ecu/obd2.ecuxml
[TRACE] 10/3/2014 21:23:54.325[HOBD] RegisterProvider: hobd.ELMSensors
[TRACE] 10/3/2014 21:23:54.340[HOBD] RegisterProvider: hobd.MAFSensors
[INFO ] 10/3/2014 21:23:54.352[LitersPerHourSensor] Using default stoich ratio
[TRACE] 10/3/2014 21:23:54.384[HOBD] RegisterProvider: hobd.CommonSensors
[TRACE] 10/3/2014 21:23:54.406[HOBD] RegisterProvider: ecuxml://ecu/default.ecuxml
[TRACE] 10/3/2014 21:23:54.432[HOBD] RegisterProvider: ecuxml://user.ecuxml
[ERROR] 10/3/2014 21:23:54.444[HOBD] bad provider ecuxml://\Storage Card\Programas\HOBD1.1.1\user.ecuxml
[DUMP ] 10/3/2014 21:23:54.552[SensorRegistry] AddListener Common.DistanceRun System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:54.571[SensorRegistry] AddListener OBD2.Speed System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 5000
[DUMP ] 10/3/2014 21:23:54.583[SensorRegistry] AddListener Common.FuelConsumed System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[TRACE] 10/3/2014 21:23:54.597[FCS] lph: MAF.LitersPerHour
[DUMP ] 10/3/2014 21:23:54.607[SensorRegistry] AddListener MAF.LitersPerHour System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 2000
[DUMP ] 10/3/2014 21:23:54.619[SensorRegistry] AddListener OBD2.MAF System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:54.633[SensorRegistry] AddListener Common.IdleTime System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:54.644[SensorRegistry] AddListener OBD2.Speed System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 2000
[DUMP ] 10/3/2014 21:23:54.654[SensorRegistry] AddListener Common.TripTime System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:54.669[SensorRegistry] AddListener OBD2.Speed System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 2000
[DUMP ] 10/3/2014 21:23:54.679[SensorRegistry] AddListener FuelConsumed_tank System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[TRACE] 10/3/2014 21:23:54.689[FCS] lph: MAF.LitersPerHour
[DUMP ] 10/3/2014 21:23:54.702[SensorRegistry] AddListener MAF.LitersPerHour System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 2000
[DUMP ] 10/3/2014 21:23:54.712[SensorRegistry] AddListener FuelConsumed_fueling System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[TRACE] 10/3/2014 21:23:54.722[FCS] lph: MAF.LitersPerHour
[DUMP ] 10/3/2014 21:23:54.732[SensorRegistry] AddListener MAF.LitersPerHour System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 2000
[DUMP ] 10/3/2014 21:23:54.745[SensorRegistry] AddListener DistanceRun_fueling System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:54.755[SensorRegistry] AddListener OBD2.Speed System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 5000
[DUMP ] 10/3/2014 21:23:54.809[SensorRegistry] TriggerListeners Common.DistanceRun 0
[DUMP ] 10/3/2014 21:23:54.828[SensorRegistry] TriggerListeners Common.FuelConsumed 0
[DUMP ] 10/3/2014 21:23:54.846[SensorRegistry] ListenerHandler Common.DistanceRun 63530083434025
[DUMP ] 10/3/2014 21:23:54.859[SensorRegistry] ListenerHandler Common.FuelConsumed 63530083434038
0 0
S c a l e A l p h a59[SensorRegistry] ListenerHandler Common.FuelConsumedn s \ P a i n t . i c o
S c a l e A l p h a = 8 0
±‹\Þ+¿žë©ÂïÒ[Å.ÚÆ0øvÛ²Gsc¨¿“[DUMP ] 10/3/2014 21:23:54.899[SensorRegistry] TriggerListeners Common.IdleTime 0
[DUMP ] 10/3/2014 21:23:54.905[SensorRegistùžlÉä>ñˆÒi áßÀù44÷„Š”‘|\eêx‘¬œÜÜe‚@oaWçÒtJ¼jƒ¹*ŒcõÖ‚’TïjÓyİk².I€Ì˜Y½.n.Ö“ãhry] ListenerHandler Common.TripTime 63530083434084
[DUMP ] 10/3/2014 21:23:54.926[SensorRegistry] TriggerListeners FuelConsumed_tank 0
[DUMP ] 10/3/2014 21:23:54.946[SensorRegistry] ListenerHandler FuelConsumed_tank 63530083434125
UMP ] 10/3/2014 21:23:54.936[SensorRegistry] ListenerHandler FuelConsumed_tank 63530083434125
# C o n n e c t
I C O N X P B U T T O N
x = 6 7 2
y = 2 1 5
O f f s e t = 0
C o m m a n d = SensorRegistry] ListenerHandler FuelConsumed_tank 635300[DUMP ] 10/3/2014 21:23:54.978[SensorRegistry] TriggerListeners DistanceRun_fueling 0
[DUMP ] 10/3/2014 21:23:54.981[SensorRe \ I c o n s \ c o n n e c t . i c o
I c o n P u sgistry] ListenerHandler FuelConsumed_fueling 63530083434160
[DUMP ] 10/3/2014 21:23:55.017[SensorRegistry] ListenerHandler DistanceRun_fueling 63530083434196
[DUMP ] 10/3/2014 21:23:55.040[SensorRegistry] AddListener Common.DistanceRun System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:55.051[SensorRegistry] AddListener Common.FuelConsumed System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:55.061[SensorRegistry] AddListener Common.TripTime System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:55.074[SensorRegistry] AddListener Common.IdleTime System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:55.085[SensorRegistry] AddListener FuelConsumed_tank System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:55.098[SensorRegistry] AddListener FuelConsumed_fueling System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:55.108[SensorRegistry] AddListener DistanceRun_fueling System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:55.159[SensorRegistry] AddListener OBD2.CoolantTemp System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 60000
[DUMP ] 10/3/2014 21:23:55.175[SensorRegistry] AddListener OBD2.LTFT1 System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 60000
[DUMP ] 10/3/2014 21:23:55.186[SensorRegistry] AddListener OBD2.LTFT2 System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 60000
[DUMP ] 10/3/2014 21:23:55.197[SensorRegistry] AddListener OBD2.MIL System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 300000
[DUMP ] 10/3/2014 21:23:55.211[SensorRegistry] AddListener OBD2.PMIL System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 300000
[TRACE] 10/3/2014 21:23:55.417[HOBD] Connecting stream: btspp://000D18A04E35;pin=1234
[INFO] 10/3/2014 21:23:55.532[HOBD] system width: 800, height: 480
[INFO] 10/3/2014 21:23:55.542[HOBD] wa width: 800, wa height: 454
[TRACE] 10/3/2014 21:23:56.999[HomePage] tap distance 26
[INFO] 10/3/2014 21:23:57.163[HomePage] System DPI: 96
[INFO] 10/3/2014 21:23:57.187[HomePage] App DPI: 57
[INFO] 10/3/2014 21:23:57.204[HomePage] layout: 475x269
[INFO] 10/3/2014 21:23:57.480[HomePage] form: 242x293
[INFO ] 10/3/2014 21:23:59.636[HomePage] no layout file user.layout
[DUMP ] 10/3/2014 21:23:59.962[SensorRegistry] AddListener Common.FuelLevel System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:59.986[SensorRegistry] AddListener FuelInTank System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:24:00.005[SensorRegistry] AddListener FuelConsumed_tank System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 10000
[DUMP ] 10/3/2014 21:24:00.062[SensorRegistry] AddListener Common.FuelEconomy_trip System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:24:00.092[SensorRegistry] AddListener Common.DistanceRun System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 2000
[DUMP ] 10/3/2014 21:24:00.103[SensorRegistry] AddListener Common.FuelConsumed System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 2000
[DUMP ] 10/3/2014 21:24:00.113[SensorRegistry] AddListener ELM.BatteryVoltage System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 5000
[DUMP ] 10/3/2014 21:24:00.128[SensorRegistry] AddListener OBD2.RPM System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:24:00.139[SensorRegistry] AddListener OBD2.Speed System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:24:00.152[SensorRegistry] AddListener Common.Acceleration System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:24:00.169[SensorRegistry] AddListener OBD2.Speed System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 3000
[DUMP ] 10/3/2014 21:24:00.180[SensorRegistry] AddListener OBD2.CoolantTemp System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 10000
[DUMP ] 10/3/2014 21:24:00.191[SensorRegistry] AddListener OBD2.IntakeAirTemp System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 10000
[DUMP ] 10/3/2014 21:24:00.205[SensorRegistry] AddListener OBD2.AirTemp System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 10000
[DUMP ] 10/3/2014 21:24:00.216[SensorRegistry] TriggerListeners Common.DistanceRun 63530083434025
[DUMP ] 10/3/2014 21:24:00.226[SensorRegistry] TriggerListeners Common.FuelConsumed 63530083434038
[DUMP ] 10/3/2014 21:24:00init>ATSP 0</engine-init>
<sensors>hobd.ELMSensors<.234[SensorRegistry] ListenerHandler Common.DistanceRun 63530083439413
[DUMP ] 10/3/2014 21:24:00.258[SensorRegistry] TriggerListeners Common.TripTime 63530083434084
[DUMP ] 10/3/2014 21:24:00.278g PID Lambda11
at hobd.ECUXMLSe[SensorRegistry] TriggerListeners Common.FuelEconomy_trip 0
[DUMP ] 10/3/2014 21:24:00.325[SensorRegistry] ListenerHandler Common.FuelConsumed 63530083439504
[DUMP ] 10/3/2014 21:24:00.335[SensorRegistry] TriggerListeners Common.FuelEconomy_trip 0
[DUMP ] 10/3/2014 21:24:00.344[SensorRegistry] ListenerHandler Common.FuelEconomy_trip 63530083439523
[DUMP ] 10/3/2014 21:24:00.360[SensorRegistry] ListenerHandler Common.FuelEconomy_trip 63530083439539
[DUMP ] 10/3/2014 21:24:00.371[SensorRegistry] TriggerListeners Common.IdleTime 63530083434116
[DUMP ] 10/3/2014 21:24:00.381LAN šr<X@W@ '/[?W ´ Bs . l a n Šg ÿÿÿÿÿÿÿÿ ÿÿÿÿi t . h o Šb d s e n s o r ITHOBD~1L[SensorRegistry] ListenerHandler Common.TripTime 63530083439560
[DUMP ] 10/3/2014 21:24:00.403[SensorRegistry] TriggerListeners FuelConsumed_tank 63530083434125
[DUMP ] 10/3/2014 21:24:00.413[SensorRegistry] ListenerHandler Common.IdleTime 63530083439592
[DUMP ] 10/3/2014 21:24:00.425[SensorRegistry] ListenerHandler FuelConsumed_tank 63530083439604
[DUMP ] 10/3/2014 21:24:00.436[SensorRegistry] TriggerListeners FuelInTank 0
[DUMP ] 10/3/2014 21:24:00.447[SensorRegistry] ListenerHandler FuelInTank 63530083439626
[DUMP ] 10/3/2014 21:24:00.457[SensorRegistry] TriggerListeners Common.FuelLevel 0
[DUMP ] 10/3/2014 21:24:00.467[SensorRegistry] ListenerHandler Common.FuelLevel 63530083439645
[TRACE] 10/3/2014 21:24:00.536[OBD2Engine] -> INIT
[INFO ] 10/3/2014 21:24:01.435[OBD2Engine] Open btspp://000D18A04E35;pin=1234
[TRACE] 10/3/2014 21:24:02.225[BluetoothStream] Open 000D18A04E35 serviceid pin 1234
[TRACE] 10/3/2014 21:24:04.180[OBD2Engine] -> ATZ
[TRACE] 10/3/2014 21:24:04.231[OBD2Engine] SendCommand:ATZ
[DUMP ] 10/3/2014 21:24:04.316[OBD2Engine] BUFFER: ?
[DUMP ] 10/3/2014 21:24:05.082[OBD2Engine] BUFFER: ?
ELM327 v1.5
[TRACE] 10/3/2014 21:24:05.112[OBD2Engine] HandleReply: ?
ELM327 v1.5
[TRACE] 10/3/2014 21:24:05.126[OBD2Engine] SendCommand:ATZ
[DUMP ] 10/3/2014 21:24:05.188[OBD2Engine] BUFFER: ATZ
[DUMP ] 10/3/2014 21:24:05.950[OBD2Engine] BUFFER: ATZ
ELM327 v1.5
[TRACE] 10/3/2014 21:24:05.970[OBD2Engine] HandleReply: ATZ
ELM327 v1.5
[INFO] 10/3/2014 21:24:05.980[OBD2Engine] VersionInfo: ?ELM327 v1.5
[TRACE] 10/3/2014 21:24:05.989[OBD2Engine] -> ATE0
[TRACE] 10/3/2014 21:24:06.036[OBD2Engine] SendCommand:ATE0
[DUMP ] 10/3/2014 21:24:06.098[OBD2Engine] BUFFER: ATE0
OK
[TRACE] 10/3/2014 21:24:06.108[OBD2Engine] HandleReply: ATE0
OK
[TRACE] 10/3/2014 21:24:06.117[OBD2Engine] -> ATL0
[TRACE] 10/3/2014 21:24:06.164[OBD2Engine] SendCommand:ATL0
[DUMP ] 10/3/2014 21:24:06.230[OBD2Engine] BUFFER: OK
[TRACE] 10/3/2014 21:24:06.240[OBD2Engine] HandleReply: OK
[TRACE] 10/3/2014 21:24:06.249[OBD2Engine] -> EXTRAINIT
[TRACE] 10/3/2014 21:24:06.333[OBD2Engine] SendCommand:ATSP 0
[DUMP ] 10/3/2014 21:24:06.394[OBD2Engine] BUFFER: OK
[TRACE] 10/3/2014 21:24:06.404[OBD2Engine] HandleReply: OK
[TRACE] 10/3/2014 21:24:06.413[OBD2Engine] -> EXTRAINIT
[TRACE] 10/3/2014 21:24:06.460[OBD2Engine] -> SENSOR_INIT
[TRACE] 10/3/2014 21:24:06.510[OBD2Engine] SendCommand:0100
[DUMP ] 10/3/2014 21:24:06.572[OBD2Engine] BUFFER: SEARCHING...
[DUMP ] 10/3/2014 21:24:11.798[OBD2Engine] BUFFER: SEARCHING...
UNABLE TO CONNECT
