small and large changes
Common discussion area
cventurer
Сообщение cventurer »
If I can I ask for some changes to the application (standalone version CE6):
1. Insert a loading screen (black screen with writing hobdrive / loading ...), because I see the loading screen of my GPS unit and do not understand if you're loading the program.
2. replace the graphic with background images such as:
example:
sensor: engine temperature
red-green: 80,50,20
images: tmp_engine_3.bmp, tmp_engine_2, tmp_engine_1
text: true, false (this is to see the text over the image)
3. replace the graphic with the text:
example:
red-green: 80,50,20
Text: warm, normal, cold
4. be able to start another application, how does wolfncu. Sometimes I need to use the GPS Navigator, with hobd.
5. be able to chose the sensor in the sensor editor
Excuse me if I ask a lot of changes, but can greatly improve your application.
thanks thanks thanks
