Cannot read fuel level
Добавлено: 06 сен 2012, 15:10
wagnerw
Hi! Im using the hobd evaluation version in a GM corsa C. Most of the readings are ok, but I cannot read the fuel level. This is a limitation of evaluation version or I have to configure it?
thanks!
Re: Cannot read fuel level
Добавлено: 07 сен 2012, 04:33
Real fuel level is supported only on a small percent of vehicles.
Both demo and full version support "estimated" fuel level by default: you should first setup your current level, enter all fueling records - then hobdrive will calculate current level for you.
Добавлено: 20 сен 2013, 15:27
stive951
I know these may be too much to ask for you to help me with these sensors, so I would like to thank you in advance even if there are not enough information for you to get going with it or there are too complicated to merage into hobdrive.
