Currency setup (£)
Добавлено: 30 янв 2013, 00:23
mohammedwaseems
Hi, Thanks for this Cali.
I have one question. I am hanging around the UI for my own personal preference just now. I am removing the russian price symbol and trying to insert the british £ symbol to use and display instead.
No matter how I try and place the £ into the config file on screen when HOBD is running it will not diplay the symbol just a square in it's place.
How would I get the £ symbol inserted. Do I have to call a specific ASCII character in machine code?
Thanks in advance.
Waz.
Re: Layout manual edit guide
Добавлено: 30 янв 2013, 10:32
Have you tried to enter fuel price dialog, and enter this symbol £ directly in there? This should work.
Добавлено: 31 янв 2013, 03:10
mohammedwaseems
that worked!!
Excellent, thank you! I have been wanting to sort that since I installed the full programme! Perhaps you should write this functionality for others in a sticky note? I know people in the UK or say Japan would appreciate it!
Fantastic programme by the way. I have the android version also and I am very impressed with the port. Of course on a fast android Dynavin carp and a can bus connection it runs very very smoothly - almost OEM smooth. So, sir - I congratulate you on a job well done!
Well worth the money.
Re: Currency setup (£)
Добавлено: 31 янв 2013, 04:58
Thanks for the good words, working handly to improve it further.
Will clarify this better in users manual.
Добавлено: 14 фев 2018, 02:32
osmosm
In iphone, you can not set to other currencies. For example, how to I set up TL (Turkish Lira).
Thank.
Добавлено: 14 фев 2018, 13:55
think thats a limitation now. Will work on this.
