Need Help
Добавлено: 18 апр 2013, 12:29
tezzablue
Hi
I have a Chinese standalone GPS/Media player with bluetooth running Wince5/6 .I dowloaded the wince 32 and it would not install. I am not sure if this one was the right one I am computer illiterate I would like some advise and help as I am interested in buying the full version. The Win32 works on my PC.
Thanks
Re: Need Help
Добавлено: 18 апр 2013, 13:20
tezzablue,
You probably need to download and unpack "standalone" package version (this one is for wince systems). Check it out.
Re: Need Help
Добавлено: 19 апр 2013, 01:42
tezzablue
Thanks for your quick reply I have downloaded the stand alone but how do I install it on the device.
Thanks
Re: Need Help
Добавлено: 19 апр 2013, 17:03
We can't provide details for each particular device (they are too different),
but in general you should unpack hobdrive into sd card and then start it from your gps unit.
Please read user's manual - it contains some references.
Re: Need Help
Добавлено: 18 июн 2013, 05:11
morto
estou com um problema no meu Bak BK-GPS4307, eu instalo o hobdrive e quando eu desligo e ligo novamente aparece um erro .Net CF. Pede para eu instalar novamente o Net compact Framework 3.5
Re: Need Help
Добавлено: 05 авг 2013, 05:11
Это к сожалению не к нам, вам надо искать модель вашей магнитолы, возможно есть английские прошивки. 4pna.com в помощь.
