"Fuel per hour" sensor is incorrect in the latest version
Добавлено: 31 май 2013, 22:13
yillw
Hi Cal,
I just purchased the full version few days ago.
I noticed the "Fuel per Hour" sensor under "Trip computer" is not showing the correct value.
Note: with the demo version it is correct. with the full version even the unit is displayed incorrectly, (L/100km and MPG) , these are incorrect unit. In particular, when using the US unit for display, the "fuel per hour" is showing around 150 at idle, when it should have been 0.4~0.6 Gal/hour.
With the demo version the value and display unit are all correct, but not the full version.
I have send email to support about this, all I got was stqandard answer, check your setting etc......
Pleas look into this, it seems the formula is worng in the calculation for this sensor.
Thanks inadvance.
Wilson
Re: "Fuel per hour" sensor is incorrect in the latest versio
Добавлено: 04 июн 2013, 21:02
Hi, Thats a bug, you may update to latest beta where it is fixed.
See here:
viewtopic.php?f=2&t=63
