Seat Leon TDI with Roadrover IAI7037V2
Ren001
Сообщение Ren001 »
I just bought Hobrive after successfully establishing communication between my Seat Leon with USB OBD2 and the Roadrover IAI7037V2 with USB Dongle (using the test version HOBD).
Btw: I have replaced the "audi.jpg" in Themes with a Seat logo.
When looking at the log I see some error messages. What does "bad provider ecu.xml" mean?
When connectiong via USB Dongle, the indicator turns green and the coolant temperature is displayed (no engine running).
The log says:
[INFO] 14.07.2012 17:29:11.001[HOBD]  HOBD 1.1.1 24.02.2012  14:34
[INFO] 14.07.2012 17:29:11.161[HOBD]  Env: 3.5.7283.0
[INFO] 14.07.2012 17:29:12.693[HOBD]  SN: 00540054-0034-0058-0030-545434583042445F3000
[INFO] 14.07.2012 17:29:12.986[HOBD]  Vehicle: Seat Leon
[ERROR] 14.07.2012 17:29:13.157[HOBD]  bad provider ecuxml://\Storage Card\Programme\HobDrive\ecu/obd2.ecuxml
System.Exception: unknown tag `command` while creating PID Lambda11
   at hobd.ECUXMLSensorProvider.init(SensorRegistry registry)
   at hobd.ECUXMLSensorProvider.Activate(SensorRegistry registry)
   at hobd.SensorRegistry.RegisterProvider(SensorProvider provider)
   at #=queSlQ6WOwqlLYH3QsyFJK3LG9wDtR6wuXiVTPMnBgSo=.#=qYbfmgSv9IK7nU8yg9itpObmzP2a8HTUFWGe0jLVvkvE=(String #=qCpA2yT9JmyyxP5CYdok8Cw==)
   at #=queSlQ6WOwqlLYH3QsyFJK3LG9wDtR6wuXiVTPMnBgSo=.#=q4p1l7P2TL5YDzMbY2p0Dew==()
   at #=queSlQ6WOwqlLYH3QsyFJK3LG9wDtR6wuXiVTPMnBgSo=.#=qNkRdgpRnBCG8_s7mBF4X6g==()
   at #=qemyrhFzVjqMRdsGEWu$9lQ==.#=qrIZO76EQPMJEaiXgp3O51Q==()
   at #=qsn5YiReJqOOgWguWkwcpkg==.#=qp$Y68N4sL$EWs2aDqswyWA==(String[] #=qM$ch0Osy81ygpZG0onoQ5g==)
[ERROR] 14.07.2012 17:29:13.280[HOBD]  bad provider ecuxml://\Storage Card\Programme\HobDrive\user.ecuxml
System.IO.FileNotFoundException: An error message is available for this exception but cannot be displayed because these messages are optional and are not currently installed on this device. Please install ‘NETCFv35.Messages.EN.wm.cab’ for Windows Mobile 5.0 and above or  ‘NETCFv35.Messages.EN.cab’ for other platforms. Restart the application to see the message.
[INFO] 14.07.2012 17:29:13.705[HOBD]  system width: 800, height: 480
[INFO] 14.07.2012 17:29:13.719[HOBD]  wa width: 800, wa height: 454
[INFO] 14.07.2012 17:29:15.055[HomePage]  System DPI: 96
[INFO] 14.07.2012 17:29:15.073[HomePage]  App DPI: 57
[INFO] 14.07.2012 17:29:15.082[HomePage]  layout: 475x269
[INFO] 14.07.2012 17:29:15.104[HomePage]  form: 242x293
[INFO] 14.07.2012 17:29:25.612[OBD2Engine]  VersionInfo: ELM327 v1.5
[INFO] 14.07.2012 17:29:26.161[OBD2Engine]  Sensor Init:41 00 98 3B A0 11
41 00 98 18 00 01
[INFO] 14.07.2012 17:29:26.241[OBD2Engine]  ProtocolId: 6
[ERROR] 14.07.2012 17:29:28.075[MILTrace]  dataraw: 43 00 43 00
[ERROR] 14.07.2012 17:29:28.207[MILTrace]  dataraw: 47 00 47 00
[ERROR] 14.07.2012 17:29:29.229[MILTrace]  dataraw: 43 00 43 00
[ERROR] 14.07.2012 17:29:31.914[VehicleForm]  LoadModel
System.ArgumentNullException: ArgumentNullException
   at System.Double.Parse(String s, NumberStyles style, IFormatProvider provider)
   at System.Double.Parse(String s, IFormatProvider provider)
   at #=qsNd0vr3JL1jqtJeODxSSpm3LVgar9PiwhbwVd83ntYA=.#=qzEmE66fikSaTLWrz$AWBSg==()
   at #=qsNd0vr3JL1jqtJeODxSSpm3LVgar9PiwhbwVd83ntYA=.#=qcC9C1AyOp5bmEBB6gfKnt1b$dXeBuWujEOmfZrC9IAw=()
   at #=qsNd0vr3JL1jqtJeODxSSpm3LVgar9PiwhbwVd83ntYA=..ctor(Form #=qitNwZiA0QeKVQOcDoxU50Q==)
   at hobd.HomePage.#=q$5aNkDzW5Yv_NfXBIMtS9g==(#=qBMJMYTSMEd4NYTyE5bizaSWJYKefxFY8uHKOcuZrT7E= #=qPLL$o6ivrGQ$TGURQBtebQ==)
   at hobd.HomePage.#=qezklVWnb8QTEN3hVS8vyyA==(#=qBMJMYTSMEd4NYTyE5bizaSWJYKefxFY8uHKOcuZrT7E= #=q1DWEi_LAzi$$qaE1XcaGHw==)
   at hobd.HomePage.#=q4tqpcve_sKcQ8AjIfirf7A==(String #=qK_j2hSF6Ay5u4oM0XiX2$Q==, Sensor #=qa5Cg36WOWkrM4Y3mY7TpVQ==)
   at hobd.HomePage.#=q_I3dem$m9sLQXAdirR2y9WCGjlGytReoUjWlZqj7rpg=.#=qNstp_U5bub1SYCDWE1meNmk4I9mq5O6dDaaUklvT6B0=(Point #=qbxJkkxklnS9qEbcPJWnZ3w==)
   at Fleux.UIElements.UIElement.Tap(Point p)
   at Fleux.UIElements.UIElement.<>c__DisplayClassa.<Tap>b__9(UIElement el)
   at Fleux.UIElements.UIElement.TraverseHandle(Point start, Func`2 elementHandler)
   at Fleux.UIElements.Panorama.PanoramaElement.Tap(Point p)
   at Fleux.Controls.FleuxControl.<>c__DisplayClass1b.<Tap>b__19()
   at System.Reflection.RuntimeMethodInfo.InternalInvoke(RuntimeMethodInfo rtmi, Object obj, BindingFlags invokeAttr, Binder binder, Object parameters, CultureInfo culture, Boolean isBinderDefault, Assembly caller, Boolean verifyAccess, StackCrawlMark& stackMark)
   at System.Reflection.RuntimeMethodInfo.InternalInvoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean verifyAccess, StackCrawlMark& stackMark)
   at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
   at System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters)
   at System.Windows.Forms.Control.TASK.Invoke()
   at System.Windows.Forms.Control._InvokeAll()
   at System.Windows.Forms.Control.InvokeHelper(Delegate method, Boolean fSynchronous, Object[] rgobjArgs)
   at Fleux.Controls.FleuxControl.Tap(Point p)
   at Fleux.Controls.Gestures.GesturesEngine.RaiseTap(Point p)
   at Fleux.Controls.Gestures.GesturesEngine.MouseUp(Point point)
   at Fleux.Controls.FleuxControl.OnMouseUp(MouseEventArgs e)
   at System.Windows.Forms.Control.WnProc(WM wm, Int32 wParam, Int32 lParam)
   at System.Windows.Forms.Control._InternalWnProc(WM wm, Int32 wParam, Int32 lParam)
   at Microsoft.AGL.Forms.EVL.EnterMainLoop(IntPtr hwnMain)
   at System.Windows.Forms.Application.Run(Form fm)
   at Fleux.Core.FleuxApplication.Run(FleuxPage mainPage)
   at #=qemyrhFzVjqMRdsGEWu$9lQ==.#=q5ir67gooYkvb4akERGWjRQ==(String #=qPWCaamlevqDfMrc2HMTttg==)
[ERROR] 14.07.2012 17:30:34.858[MILTrace]  dataraw: 43 00 43 00
[ERROR] 14.07.2012 17:30:34.933[MILTrace]  dataraw: 47 00 47 00
Thanks
Ren001
Re: Seat Leon TDI with Roadrover IAI7037V2
Ren, internal log is abit excessive, here is actually nothing strange.
It notes about a minor bug in 1.1.1 version. I can send you a beta update if you want (but it is not yet fully tested and is abit unstable).
