Renault Megane II 2004
ddbrekhman
Сообщение ddbrekhman »
Пытаюсь подключить hobd к Renault Megane II 2004. Пока по большей части безуспешно. Удаётся только получить напряжение бортовой сети, стало быть соединение с ЭБУ не устанавливается.
Может подскажет кто чего?
В логе примерно вот это:
[INFO]   03.11.12 1:48:01 PM.377[HOBD]  Vehicle: My Vehicle
[ERROR]   03.11.12 1:48:01 PM.377[HOBD]  bad provider ecuxml://C:\Temp\ELM327\hobd_1.1.1_win32\ecu/obd2.ecuxml
System.Exception: unknown tag `command` while creating PID Lambda11
   at hobd.ECUXMLSensorProvider.init(SensorRegistry registry)
   at #=qU1vCfRhN5J3AdzDTcUrg6fL3y_Zj2D_Lh9NNG7HMAmg=.#=qKKYgZSIg9Oh1SxZXjA2ReEwj0FUg4YM6A29GDqo$RZc=(String #=qpC7gLNR93Gwf62Yoj1QPCA==)
[ERROR]   03.11.12 1:48:01 PM.377[HOBD]  bad provider ecuxml://C:\Temp\ELM327\hobd_1.1.1_win32\user.ecuxml
System.IO.FileNotFoundException: Could not find file 'C:\Temp\ELM327\hobd_1.1.1_win32\user.ecuxml'.
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath)
   at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy)
   at System.Xml.XmlReaderSettings.CreateReader(String inputUri, XmlParserContext inputContext)
[INFO]   03.11.12 1:48:01 PM.377[HomePage]  System DPI: 96
[INFO]   03.11.12 1:48:01 PM.377[HomePage]  App DPI: 30
[INFO]   03.11.12 1:48:01 PM.377[HomePage]  layout: 465x281
[INFO]   03.11.12 1:48:01 PM.377[HomePage]  form: 1496x912
[INFO]   03.11.12 1:48:05 PM.792[OBD2Engine]  VersionInfo: ELM327 v1.5
[INFO]   03.11.12 1:48:10 PM.566[OBD2Engine]  Sensor Init:SEARCHING...
41 00 00 00 00 00
[INFO]   03.11.12 1:48:10 PM.628[OBD2Engine]  ProtocolId: 5
[ERROR]   03.11.12 1:48:11 PM.861[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]   03.11.12 1:48:12 PM.173[MILTrace]  dataraw: 7F 07 11
[ERROR]   03.11.12 1:48:20 PM.878[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]   03.11.12 1:48:21 PM.158[MILTrace]  dataraw: 7F 07 11
[ERROR]   03.11.12 1:48:24 PM.263[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]   03.11.12 1:48:24 PM.512[MILTrace]  dataraw: 7F 07 11
[ERROR]   03.11.12 1:48:37 PM.273[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]   03.11.12 1:48:37 PM.523[MILTrace]  dataraw: 7F 07 11
[ERROR]   03.11.12 1:48:41 PM.267[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]   03.11.12 1:48:41 PM.517[MILTrace]  dataraw: 7F 07 11
Re: Renault Megane II 2004
Интересный экземпляр. Ваш рено честно сообщает по протоколу OBD2, что ни одного датчика из OBD2 стандарта он не поддерживает.
Хотя ошибки читать должен, судя по логу.
Вполне вероятно что по дилерскому протоколу он как-то должен работать.
Есть темка: viewtopic.php?f=20&t=236
там человек пытается разобрать дилерский протокол.. последите - возможно вам поможет.
PS. Попробуйте выставите профиль "nissan custom" - вдруг..
ddbrekhman
cail писал(а):Интересный экземпляр.
Да уж...
Ошибки похоже тоже не читает - я собственно в основном из-за этого и покупал адаптер. Иногда выскакивает одна зловредная ошибка, которая если в памяти оседает, то сильно влияет на работу двигателя. Надоело ездить к мастерам её скидывать, с дилерским-то прибором всё работает.
Как-то можно проверить чтение ошибок и сброс? У меня в окне DTC никакой путной информации не выводится. Попробую снять лог при заходе в него.
А вообще люди к Megane II подключались c ELM327, но возможно год другой - там разные ЭБУ ставили. http://www.megane-club.ru/forum/index.p ... ntry867436
темку Renault-Nissan тоже видел, но там у человека хоть стандартные сенсоры читаются.
nissan custom пробовал - ничего хорошего не получилось, если правильно помню даже напряжение при этом не показывалось.
Судя по логам инфу об ошибках отдает (но сейчас у вас их нет).
Выдерните какой-нибудь датчик чтобы поднять ошибку (дмрв например) - иначе никак не проверить.
ddbrekhman
cail писал(а):Судя по логам инфу об ошибках отдает (но сейчас у вас их нет).
:) У меня сейчас точно есть ошибки, как раз потому что выдернут разъём из клапана регулировки фазика. Потому что без этого двигатель глохнет из-за старой висящей в памяти ошибки по дпкв. Ну и ещё там всегда болтается ошибка цепи подогрева второй лямбды.
В общем ошибок предостаточно, но hobd ничего не показывает.
Значит по obd2 вообще ничего машинка не отдает.
ddbrekhman
А какое место в логе соответсвует запросу ошибок и ответу, что ошибок нет? Или этого в логе не видно?
ddbrekhman
мда, похоже всё так и есть машинка вроде по OBD-2 соединяется, но ничего отдавать не хочет
поставил французскую программу, вдруг думаю они своих получше поддержали - та же картина соединились, вроде что-то поддерживается, но ни информации по сенсорам не отдаёт, ни ошибок
Ещё попробовал лог снять в режиме подключения "Nissan custom" - вся инициализация как бы проходит, но в конце, когда идёт попытка чтения - ошибка. Есть смысл ещё что-то попробовать?
(5.32 КБ) 1264 скачивания
Похоже что нет.
Поищите информацию по дилерским протоколам рено.. я не нашел с лету ничего.
