I downloaded the free test version to see how I like your program. I'm having trouble with the initial setup; I can get it to connect and show a green light in the bottom left. However, I have thus far been unable to get it to monitor any of the vehicle parameters. Which options do I need to choose for a 2006 GMC Duramax Diesel 2500HD?
Thanks
2006 GMC Duramax LBZ
Re: 2006 GMC Duramax LBZ
Hi.
Do you mean you don't see any sensor values at all?
Try to choose ELM Init Template "ELM Reset" in vehicles settings. If this does not help, please put here file "log.txt" from your "hobdrive" folder on flash card.
Here is the log, I don't see any sensor values at all...
- (546.45 КБ) 1161 скачивание
7mmSTW,
I don't see any signs of successful connection to ELM Bluetooth.
Please check that ELM is paired in system BT settings. Also check that no other ELM program is running.
