Версия андроид лицензия.Установлен профиль х-траил 2008. Интересует именно нативный ниссановский протокол, для остального есть красивый и вылизаный torque.
Заранее спасибо за помощь.
[ TRACE] 15.05.2013 16:51:58.513[OBD2Engine] -> ERROR_SOFT
[TRACE] 15.05.2013 16:52:18.520[OBD2Engine] -> INIT
[TRACE] 15.05.2013 16:52:18.785[OBD2Engine] -> ATZ
[TRACE] 15.05.2013 16:52:18.835[OBD2Engine] SendCommand:ATZ
[TRACE] 15.05.2013 16:52:19.743[OBD2Engine] HandleReply: ELM327 v1.4
[INFO] 15.05.2013 16:52:19.744[OBD2Engine] VersionInfo: ELM327 v1.4
[TRACE] 15.05.2013 16:52:19.745[OBD2Engine] -> ATE0
[TRACE] 15.05.2013 16:52:19.988[OBD2Engine] SendCommand:ATE0
[TRACE] 15.05.2013 16:52:20.039[OBD2Engine] HandleReply: ATE0
OK
[TRACE] 15.05.2013 16:52:20.040[OBD2Engine] -> ATL0
[TRACE] 15.05.2013 16:52:20.168[OBD2Engine] SendCommand:ATL0
[TRACE] 15.05.2013 16:52:20.225[OBD2Engine] HandleReply: OK
[TRACE] 15.05.2013 16:52:20.226[OBD2Engine] -> EXTRAINIT
[TRACE] 15.05.2013 16:52:20.235[OBD2Engine] SendCommand:ATSP5
[TRACE] 15.05.2013 16:52:20.290[OBD2Engine] HandleReply: OK
[TRACE] 15.05.2013 16:52:20.291[OBD2Engine] -> EXTRAINIT
[TRACE] 15.05.2013 16:52:20.415[OBD2Engine] SendCommand:ATAL
[TRACE] 15.05.2013 16:52:20.466[OBD2Engine] HandleReply: OK
[TRACE] 15.05.2013 16:52:20.467[OBD2Engine] -> EXTRAINIT
[TRACE] 15.05.2013 16:52:20.475[OBD2Engine] SendCommand:ATIB10
[TRACE] 15.05.2013 16:52:20.533[OBD2Engine] HandleReply: OK
[TRACE] 15.05.2013 16:52:20.533[OBD2Engine] -> EXTRAINIT
[TRACE] 15.05.2013 16:52:20.647[OBD2Engine] SendCommand:ATSH8110FC
[TRACE] 15.05.2013 16:52:20.701[OBD2Engine] HandleReply: OK
[TRACE] 15.05.2013 16:52:20.702[OBD2Engine] -> EXTRAINIT
[TRACE] 15.05.2013 16:52:20.714[OBD2Engine] SendCommand:ATST32
[TRACE] 15.05.2013 16:52:20.766[OBD2Engine] HandleReply: OK
[TRACE] 15.05.2013 16:52:20.766[OBD2Engine] -> EXTRAINIT
[TRACE] 15.05.2013 16:52:20.831[OBD2Engine] SendCommand:ATSW00
[TRACE] 15.05.2013 16:52:20.882[OBD2Engine] HandleReply: OK
[TRACE] 15.05.2013 16:52:20.882[OBD2Engine] -> EXTRAINIT
[TRACE] 15.05.2013 16:52:20.895[OBD2Engine] -> SENSOR_INIT
[TRACE] 15.05.2013 16:52:20.901[OBD2Engine] SendCommand:0100
[TRACE] 15.05.2013 16:52:21.813[OBD2Engine] HandleReply: BUS INIT: ERROR
[ERROR] 15.05.2013 16:52:21.814[OBD2Engine] Critical error on sensor init:BUS INIT: ERROR
[TRACE] 15.05.2013 16:52:21.814[OBD2Engine] -> ERROR_SOFT
[TRACE] 15.05.2013 16:52:25.281[HomeActivity] OnPause
[TRACE] 15.05.2013 16:52:25.911[HomeActivity] OnStop
[TRACE] 15.05.2013 16:52:30.809[HomeActivity] OnStart
[TRACE] 15.05.2013 16:52:30.810[HomeActivity] OnWindowAttributesChanged
[TRACE] 15.05.2013 16:52:30.813[HomeActivity] OnResume
[INFO ] 15.05.2013 16:52:30.852[HOBD] hobd locale: ru android: ru
[TRACE] 15.05.2013 16:52:31.030[HomePage] tap distance 67
[INFO] 15.05.2013 16:52:31.040[HomePage] System DPI: 240
[INFO] 15.05.2013 16:52:31.041[HomePage] App DPI: 144
[INFO] 15.05.2013 16:52:31.041[HomePage] layout: 288x457
[INFO ] 15.05.2013 16:52:31.599[HomePage] no layout file user.layout
[TRACE] 15.05.2013 16:52:35.250[AndroidBT] Closing
[TRACE] 15.05.2013 16:52:35.261[AndroidBT] Closed
[TRACE] 15.05.2013 16:52:35.350[HomeActivity] OnPause
[TRACE] 15.05.2013 16:52:35.959[HomeActivity] OnStop
[TRACE] 15.05.2013 16:52:35.960[HomeActivity] OnDestroy
