[INFO] 6/27/2012 7:09:01 PM.001[HOBD] HOBD 1.1.1 29.02.2012 13:19
[INFO] 6/27/2012 7:09:01 PM.132[HOBD] Env: 3.5.7283.0
[INFO] 6/27/2012 7:09:03 PM.025[HOBD] SN: 00540054-0034-0058-0030-545434583042445F3000
[INFO] 6/27/2012 7:09:03 PM.607[HOBD] Vehicle: My Vehicle
[ERROR] 6/27/2012 7:09:04 PM.304[HOBD] bad provider ecuxml://\Storage Card\hobd\user.ecuxml
System.IO.FileNotFoundException: An error message is available for this exception but cannot be displayed because these messages are optional and are not currently installed on this device. Please install ‘NETCFv35.Messages.EN.wm.cab’ for Windows Mobile 5.0 and above or ‘NETCFv35.Messages.EN.cab’ for other platforms. Restart the application to see the message.
at #=qPc42lWHPoKxIqKdcjwMgbzOeBwIB1hBW3db4DxsshaE=.#=qYS30yvukWtx47te4aQsStWF5XhVpKTjCxQgTQK$8qzw=(String #=qTz48NWnxmwHlsbiLP01Cwg==)
at #=qPc42lWHPoKxIqKdcjwMgbzOeBwIB1hBW3db4DxsshaE=.#=qzxMhj8Gh2rCc4Bbh6IsDgQ==()
at #=qPc42lWHPoKxIqKdcjwMgbzOeBwIB1hBW3db4DxsshaE=.#=qU_NaK4iQgFsz2eVBQQIT3A==()
at #=q_mMq$NOUI_Mh5XgmJXNMWw==.#=q4X9QL3AHYVnqpOvWKfJm7Q==()
at #=qcYnIe2yAE8WwfyM2YoPa6c$Chdcbj19kQ7Tt9gXXWiM=.#=q9G0e0sdmJBhMIik8S7yjzA==(String[] #=qSh09aj13RyzMSIKnTMESqg==)
[INFO] 6/27/2012 7:09:05 PM.143[HOBD] system width: 800, height: 480
[INFO] 6/27/2012 7:09:05 PM.159[HOBD] wa width: 800, wa height: 480
[INFO] 6/27/2012 7:09:05 PM.873[HOBDAll] hobDrive registered: hdtco4740289376 - Raphael Pais
[INFO] 6/27/2012 7:09:07 PM.009[HomePage] System DPI: 96
[INFO] 6/27/2012 7:09:07 PM.024[HomePage] App DPI: 57
[INFO] 6/27/2012 7:09:07 PM.037[HomePage] layout: 475x285
[INFO] 6/27/2012 7:09:07 PM.055[HomePage] form: 242x293
[ERROR] 6/27/2012 7:09:23 PM.022[OBD2Engine] Init Error
System.Net.Sockets.SocketException: An error message is available for this exception but cannot be displayed because these messages are optional and are not currently installed on this device. Please install ‘NETCFv35.Messages.EN.wm.cab’ for Windows Mobile 5.0 and above or ‘NETCFv35.Messages.EN.cab’ for other platforms. Restart the application to see the message.
at System.Net.Sockets.Socket.ConnectNoCheck(EndPoint remoteEP)
at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
at InTheHand.Net.Sockets.SocketBluetoothClient.Connect(BluetoothEndPoint remoteEP)
at InTheHand.Net.Sockets.BluetoothClient.Connect(BluetoothEndPoint remoteEP)
at hobd.BluetoothStream.Open(String url)
at hobd.OBD2Engine.Run()
[ERROR] 6/27/2012 7:10:00 PM.181[OBD2Engine] Init Error
System.Threading.ThreadAbortException: ThreadAbortException
[ERROR] 6/27/2012 7:10:04 PM.500[VehicleForm] LoadModel
System.ArgumentNullException: ArgumentNullException
at System.Double.Parse(String s, NumberStyles style, IFormatProvider provider)
at System.Double.Parse(String s, IFormatProvider provider)
at #=q5JnDHXv9AGMsDlnbIh7501gbE9GujXikXdT0USjO$2M=.#=qnGRfpGQI7z0MNAF0KTizAQ==()
at #=q5JnDHXv9AGMsDlnbIh7501gbE9GujXikXdT0USjO$2M=.#=qn29ahhFwD6_vViwFYuP7EYPYLi4EIqMyzbOcXuB$9xM=()
at #=q5JnDHXv9AGMsDlnbIh7501gbE9GujXikXdT0USjO$2M=..ctor(Form #=qOG2nU0Q$NLrcibBznM0DtQ==)
at hobd.HomePage.#=q0VsJq4aeKpSvEluQi$Ohdg==(#=qn$k1OcXjzh18tZeN3in7xiO4dq5AypqcTEtALyT$gXY= #=qorH1Kd4AmBDhr$SbfFm7tQ==)
at hobd.HomePage.#=qzttQmebTI0bQ2iBGkat4VA==(#=qn$k1OcXjzh18tZeN3in7xiO4dq5AypqcTEtALyT$gXY= #=qweNTupbbUMXskT2TuGQjkA==)
at hobd.HomePage.#=qWJwe3QyeyaRSgNLSssaZVA==(String #=qrBHSBcmrwvXkhqAfSuyN8g==, Sensor #=qRPEyqbvesYKvmwej_E7EPg==)
at hobd.HomePage.#=qTAkifM3iirsuWsZADSHdmbE56FbZZiebZTZ8fvEZ59Y=.#=qxOaswMfymc9Nzx$2b7TSoRwWN9paPLDXJkbRPYPXYpQ=(Point #=qXxx05VTL3q9sO4WRSzpDRQ==)
at Fleux.UIElements.UIElement.Tap(Point p)
at Fleux.UIElements.UIElement.<>c__DisplayClassa.<Tap>b__9(UIElement el)
at Fleux.UIElements.UIElement.TraverseHandle(Point start, Func`2 elementHandler)
at Fleux.UIElements.Panorama.PanoramaElement.Tap(Point p)
at Fleux.Controls.FleuxControl.<>c__DisplayClass1b.<Tap>b__19()
at System.Reflection.RuntimeMethodInfo.InternalInvoke(RuntimeMethodInfo rtmi, Object obj, BindingFlags invokeAttr, Binder binder, Object parameters, CultureInfo culture, Boolean isBinderDefault, Assembly caller, Boolean verifyAccess, StackCrawlMark& stackMark)
at System.Reflection.RuntimeMethodInfo.InternalInvoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean verifyAccess, StackCrawlMark& stackMark)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters)
at System.Windows.Forms.Control.TASK.Invoke()
at System.Windows.Forms.Control._InvokeAll()
at System.Windows.Forms.Control.InvokeHelper(Delegate method, Boolean fSynchronous, Object[] rgobjArgs)
at Fleux.Controls.FleuxControl.Tap(Point p)
at Fleux.Controls.Gestures.GesturesEngine.RaiseTap(Point p)
at Fleux.Controls.Gestures.GesturesEngine.MouseUp(Point point)
at Fleux.Controls.FleuxControl.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WnProc(WM wm, Int32 wParam, Int32 lParam)
at System.Windows.Forms.Control._InternalWnProc(WM wm, Int32 wParam, Int32 lParam)
at Microsoft.AGL.Forms.EVL.EnterMainLoop(IntPtr hwnMain)
at System.Windows.Forms.Application.Run(Form fm)
at Fleux.Core.FleuxApplication.Run(FleuxPage mainPage)
at #=q_mMq$NOUI_Mh5XgmJXNMWw==.#=q2U0o1ZJsCIQgWY516yswJg==(String #=qJVailhWBGgCRpqroCofFSg==)
[ERROR] 6/27/2012 7:10:13 PM.352[BluetoothStream] set_Mode
System.ComponentModel.Win32Exception: Error setting BluetoothRadio mode
at InTheHand.Net.Bluetooth.WindowsBluetoothRadio.set_Mode(RadioMode value)
at InTheHand.Net.Bluetooth.BluetoothRadio.set_Mode(RadioMode value)
[ERROR] 6/27/2012 7:10:13 PM.453[OBD2Engine] Init Error
[INFO] 6/27/2012 7:10:30 PM.261[HOBD] Vehicle: My Vehicle
[ERROR] 6/27/2012 7:10:30 PM.369[HOBD] bad provider ecuxml://\Storage Card\hobd\user.ecuxml
[ERROR] 6/27/2012 7:10:30 PM.775[OBD2Engine] Init Error
[INFO] 6/27/2012 7:10:31 PM.451[HomePage] System DPI: 96
[INFO] 6/27/2012 7:10:31 PM.460[HomePage] App DPI: 57
[INFO] 6/27/2012 7:10:31 PM.469[HomePage] layout: 475x285
[INFO] 6/27/2012 7:10:31 PM.479[HomePage] form: 800x480
[ERROR] 6/27/2012 7:10:32 PM.499[HomePage] Invalid Action: default
[ERROR] 6/27/2012 7:10:32 PM.646[HomePage] Invalid Action: default
[ERROR] 6/27/2012 7:10:42 PM.105[BluetoothStream] set_Mode
[ERROR] 6/27/2012 7:10:42 PM.312[OBD2Engine] Init Error
[ERROR] 6/27/2012 7:11:03 PM.729[BluetoothStream] set_Mode
[ERROR] 6/27/2012 7:11:03 PM.818[OBD2Engine] Init Error
[ERROR] 6/27/2012 7:11:09 PM.579[VehicleForm] LoadModel
[INFO] 6/27/2012 7:11:22 PM.220[HOBD] Vehicle: My Vehicle
[ERROR] 6/27/2012 7:11:22 PM.253[HOBD] bad provider ecuxml://\Storage Card\hobd\user.ecuxml
[ERROR] 6/27/2012 7:11:22 PM.537[OBD2Engine] Init Error
[INFO] 6/27/2012 7:11:23 PM.253[HomePage] System DPI: 96
[INFO] 6/27/2012 7:11:23 PM.267[HomePage] App DPI: 57
[INFO] 6/27/2012 7:11:23 PM.279[HomePage] layout: 475x285
[INFO] 6/27/2012 7:11:23 PM.292[HomePage] form: 800x480
[ERROR] 6/27/2012 7:11:24 PM.193[HomePage] Invalid Action: default
[ERROR] 6/27/2012 7:11:37 PM.108[OBD2Engine] Init Error
[ERROR] 6/27/2012 7:12:11 PM.709[OBD2Engine] Init Error
H .text Ää æ `.rsrc X è @ @.reloc @ î @ B [ERROR] 6/27/2012 7:12:11 PM.746[OBD2Engine] Init Error
