Hi,
i got navking i66 navigation unit.
deleted its rıute66 and installed igo primo.
now want to install hobd but cant do it.
could you help me pls about installing hobd to it ?
- device gives .net error coz it has .net 2.0. Tried to upgrade 3.5 but couldnt do.
how can i do ?
and can you give me some tricks about making it desktop free (try to see wince desktop)
Thanks for your helps.
Sincerly.
İnstalling on Navking i66
Re: İnstalling on Navking i66
xiuh, have you tried using hobd-standalone package? this normally helps.
yes Cail,i tried but didnt work.
But will try again,and let you know if it works.
Thanks.
Thanks.
There is also a .net37 package on site in Downloads section. Try it - some people report it works.
BTW, is your device arm or mips? For mips you should have another .net35 package.
Hi Cail,
i can use standalone package but got issues about connection with elm bluetooth adapter.
So checked this forum ;
viewtopic.php?f=5&t=30
want to try to use bluetooth dongle for connection with elm.
added registry entry then run the otgloader.exe
selected otg device mode and it prompted,clicked ok.
For now,everything is fine but get a huge disappointment..
that is my device no longer connects to pc via neither activesync nor massstorage..
now my device is working on usb only for charge.. no other connection with pc.
could you help me about this sitiuation pls ?
Thanks.
Thanks.
That's normal- you can't use your device as a slave, when it is in usb host mode.
you should switch it back to slave with the same tool.
Thanks for your reply,
I tried that u mentioned but still no change occurs.
Selecting otg device mode but still no connection with pc.
Or Do i miss anything about it ?
Thanks
Thanks
In OTGLoader you should select not device, but slave mode. To revert back to usb-slave mode. Are you sure you did this?
when i run the otgloader.exe,there is 2 options appears ;
OTG Host
OTG Device
and there is no more options. select otg device the press the button under these selections,a new window opens and shows some written in russian(i think its russian but not sure).
OTG Host
OTG Device
Sorry, then you doing everything right, OTG Device should switch device back into slave mode. It strange it does not help. could you share a screenshot of a message? that could be an error..
now no errors occur but still same sitiuation continues..
i'm giving my usbotg1.reg file as an attachment,
so please could you check it ?
and can access all areas of my device via totalcommander(not from pc,using on device)
btw i cant erase or rename usbotg1 entry in registry of my device,only can copy,move and replace
thanks for your helps
USBOTG1.rar
- (244 байт) 1182 скачивания
