Hi All,
I have a Toyota Vitz 07, JDM 1.0L, Engine 1KR_FE. I was unable to use the torque application. I then found Hobdrive. When I connect to the OBD port The following happens;
It connects
I go to screens then the sensor list option
I Get RPM as percentage....not the actual RPMs(As the rev limiter kicks in the reading is 100%)
My oil temp is around 80C
My coolant temp goes to 130C
Engine load 68% (at Idle)
Vehicle settings protocol Toyota JDM CAN21
The encouraging thing is atleast the ECU is talking.....
How can we fix this??
Fascar
Toyota Vitz JDM 1.0L 1KR-FE
Re: Toyota Vitz JDM 1.0L 1KR-FE
Hello Fascar.
Please try latest beta 1.1.68 - it has toyota21 ecu with some fixes.
http://hobdrive.com/download/hobd/hobd- ... 1.1.68.apk
Hi Cail,
The version update for the demo app has WORKED...thanks.
I have also recently (1 hour ago) purchased the paid version....I have the following questions
1. The version in the paid app is 1.1.63
2. Initially it asked for license verification....which shows error
3 I am getting the wrong readings as in demo app 1.1.63
Also were can I get a manual for adjusting the HUD as per my requirement.
Fascar
Fascar
2. I've already replied you by email - sometimes google delays verification up to 6 hours. retry later.
3. I've sent you a private message with 68 full build. It however may not be stable - if so, please wait until it'll appear on market (you'll get autoupdate then).
Thanks Cail,
I shall update you of the developments.
Fascar
Fascar
