Toyota Vitz JDM 1.0L 1KR-FE
Добавлено: 20 мар 2013, 12:16
Hi All,
I have a Toyota Vitz 07, JDM 1.0L, Engine 1KR_FE. I was unable to use the torque application. I then found Hobdrive. When I connect to the OBD port The following happens;
It connects
I go to screens then the sensor list option
I Get RPM as percentage....not the actual RPMs(As the rev limiter kicks in the reading is 100%)
My oil temp is around 80C
My coolant temp goes to 130C
Engine load 68% (at Idle)
Vehicle settings protocol Toyota JDM CAN21
The encouraging thing is atleast the ECU is talking.....
How can we fix this??
Fascar
It connects
Fascar
