hobDrive beta builds
Добавлено: 18 фев 2012, 07:49
Here you can track the latest beta builds of hobd and hobdrive:
http://hobdrive.com/download/hobd/hobd-1.1.87.zip
Changes:
- v1.1.87 28/08/2013
  - android fixes: license management improvements
  - Changes in popup screens handling
  - Last minute data are now saved even on unexpected power off.
- v1.1.86 23/08/2013
  - Bug fixes
  - Android 4.x UI is improved in dialogs
- v1.1.85 20/08/2013
  - Stability improvements with data saving
- v1.1.84 19/08/2013
  - Support MIL reading in Opel via KWP
  - Support Mitsubishi MUT proto (draft)
  - New dialog to enter missing trips
  - Automatic missing trip calculation when entering a new fueling
  - Improvements in fueling dialog (full tank, custom units)
  - Popup action screens now consume full screen space
- v1.1.82 03/07/2013
  - "custom-description" allows to change sensor description
  - new values for custom-units: time12, timesec12 - for 12 hours format
  - Options for font size adaptation disabling
  - Ability to output extra sensor data as id="sensor[extradata]". For instance TripTime[fillup] always gives trip time on "Fillup" interval, independently of currently selected interval.
  - Improvements in Toyota21 ECU
- v1.1.78 29/06/2013
  - Android: Fixed resets on some HTC devices
  - CAN ERROR from ELM is now ignored
  - Lambda level3 PIDs, Cat PIDs.
  - Automatic backup of config&data in case of data failure
  - Improvements in BT search logic, in auto search screen
- v1.1.76 23/04/2013
  - HUD mode improvements
  - Fixes in reconnect timeouts
  - Windows: before sleep hobdrive tries to drop the connection link
  - Android: All dialogs now inherit orientation preference
  - Android: GPS search fixed (not worked on some devices)
- v1.1.74 11/04/2013
  - Extensions in delphi mt20u2
  - Sensor labels are now size-adapting
  - Devices with numeric keyboards can now switch screens. Each numeric key is an index of activated screen.
  - Improved translations: ua, arabic, portugues-brazil, others
- v1.1.73 06/04/2013
  - Improved vehicle profiles
  - Bug fixes
- v1.1.70 27/03/2013
  - Fixes in protocol auto-search screen.
  - Ecuxml: allow custom header specification (prius.ecuxml, feh.ecuxml)
  - Android: System android option "Development -> Force GPU Rendering" causes
    screen shifts and flickering. The recommendation is to disable this option.
- v1.1.68 17/03/2013
  - Android: WiFi restarts only when network connection error
  - Improvements in "Trip" panel, new panel "Actions"
  - New actions "Total data reset" and "UI settings reset"
  - Improved popup sensor information window
  - Sensor UI setup is available directly from sensor information popup
  - Autosearch protocol and adapter screen
  - Improved layouts, charts settings. Fixes in occasional text overlapping
  - Bug fixes
  - New ECUs:
  - Ford Escape Hybrid
  - Toyota JDM CAN (> 2006)
  - MIL codes in toyota JDM
  - Nissan Custom improvements, MIL reading
  - ecuxml new options: cutlow, cuthigh - allows value cutting on threshold.
- v1.1.63 17/12/2012
  - Terms of use dialog
  - New version updates dialog
  - Option to reset WiFi network on start (Helps to connect WiFi ELM automatically)
  - Version checks once a week
- v1.1.60 30/11/2012
  - Bosch ME1797 (UAZ Hunter, Patriot)
  - Signed values in ecuxml
- v1.1.57 20/11/2012
  - Toyota mode21 (JDM) and Delphi MT20U2
- v1.1.55 11/11/2012
  - Slovak language added (thanks to maxman!)
  - Fixed a bug with incorrectly drawn background on first start
  - Sensor Details screen was improved
- v1.1.51
  - Filter low MAF flow in consumption when engine is not running
  - GPS port speed available in settings
  - popup notifications on events
  - Improved German and Chinese translations.
    - Current screen is saved upon exit even if it was autohiding screen.
    - Chinese translation (yqyzj)
    - Timeouts for popup control menus are increased and could be tuned up via parameters.
    - Setup of popup buttons appearance via theme files
    - Improvements in units handling: English (uk gallons) and south africa (km per liter) presets are added.
    - New screen for Hybrids (full hobdrive version only).
      [b]Prius and other hybrid owners - I would like to hear from you how this could be improved further[/b]
- 1.1.55 11/11/2012
- 1.1.51
- 1.1.49
 - Fuel, saved during fuel cut calculated incorrectly during warmups and fast speedups.
 - Speed correction coefficient now works even for non-OBD2 protocols
 - ECI Sirius d42 (Chevrolet Lacetti)
- 1.1.44
 - Acteco ME797 ECU Profile
 - Режим диагностики:
   Начинают читаться только отображаемые на экране датчики.
   Включается из всплывающей панели "Статус соединения".
 - Кнопка принудительного переподключения (в панели "Статус соединения")
 - windows: gps settings in connection dialog. GPS is disabled by default
 - Suspend/Resume handling on WinXP
- 1.1.40 07/06/2012
 - Улучшения в экране диагностики. Информирует если проверка кодов ошибок недоступна, или программа еще не подключилась
 - Новый экран "Мощность". В полной версии рассчитывает Мощность двигателя и момент (текущие и максимальные).
- 1.1.38 07/06/2012
 - Экранные кнопки (Экраны, Поездка) теперь откликаются и на "листающие" жесты
 - Улучшения в синтаксисе ecuxml
 - В hud режиме фоновый рисунок опять отключается (было сломано)
 - Из пакета убраны все темы с лейблами автомобилей. Их можно скачать отдельно
 - Добавлено несколько дополнительных тем
 - Добавлено чтение кодов ошибок с KWP протоколов Tiggo, Январь (в демо версии недоступно)
- 1.1.37
 - Работа с GPS приемником. Новая вкладка GPS с информацией по местоположению.
 - Демо режим - работа без ELM адаптера с симуляцией данных по GPS.
   Имитируются скорость, обороты, и средний расход топлива!
- 1.1.36
 - Исправлено: хобдрайв не мог принимать ответы от ЭБУ больше 256 байт
 - Улучшен вид всплываюего меню "Поездка"
From this version, all future updates you can do on your own: "Screens" - "Settings" - "Network" - "Use beta channel" - "Check for updates".
For license beta updates, you should enter your account page:
enter your email, account ID.
There you can download beta packages and copy files from ZIP into your current install folder.
Verify that your original useragent.dll file is in there (that is your license) Please do backup before use. Unofficial beta releases could contain some bugs or cause problems - use these with care.
Android owners could use account page to reset serial ID activations (in case theirs phone IDs were changed for some reason)
Re: hobDrive beta builds
Добавлено: 14 май 2012, 21:16
hobdrive 1.1.27 update
Добавлено: 20 май 2012, 04:01
snivesatgt
Thanks for a great new beta release.
I am new to the hobdrive software, but am enjoying getting use to the features and functions.
One piece of feedback w/ the new version (not sure what version I had before), but it seems like the conversion for temperature (both coolant and air intake) for F is off. It looks correct when the units are C, but when I switch to F, it looks really off doing the conversion.
Thanks,
Ben
Добавлено: 21 май 2012, 14:17
Thanks, that was a typo. the conversion logic was inverted.
Will fix in next update
Добавлено: 25 май 2012, 17:19
snivesatgt
Thanks for the quick reply.
You have a great product (just purchased the full version).
I will be anxious to try out the next beta version that has that conversion fix -- let me know and I will send you my order info.
Thanks again (no rush on the next beta release version -- but let me know and and I can provide you the registration number/etc..)
Ben
Добавлено: 13 июл 2012, 16:16
kelloggs
thanks for beta 1.1.4. For feedback.....when I open a screen then try to close it with the x on top right it will not close. I can get back to normal screen by scrolling the page. Also I think the uk mpg conversion is out. I'm seeing the figure rise to over 30mpg which I think is impossible for a 240 bhp rx8. especially the way I drive :D . running winCE 6 on chinese 7" satnav. still awesome software keep up the great work.
Добавлено: 16 июл 2012, 09:18
kellogs,
UK mpg calculates using UK gallons.
could you please post here sample data: distance, fuel consumed, and fuel MPG. You may also long-click on sensor to see its value in different units (and to validate it calculates correctly).
Other cause of high MPG could be a consumption calibration. What fuel calculation method do you use?
Добавлено: 19 июл 2012, 01:49
kelloggs
hi sorry for the delay . this work stuff gets in the way . last run was 5.9 miles, fuel consumed was 0.196 gals, fuel economy shows 30.1 gall. holding sensor gives last value 9.37L/100 km and says 25.1 mpg. by my maths one is imperial gall the other is US gall. mpg method is maf sensor, I have the tank size as 60Liters in the vehicle settings, should this also be in gallons?
Добавлено: 20 июл 2012, 09:12
So thats correct.
25 us mpg is 30 uk mpg, since 1uk gallon = 1.21us gallon.
Correct me if I'm wrong, since I'm neither in us, nor in uk ;)
Tank size is always in liters, so thats fine.
Try to run out full tank with hobdrive and see if hobdrive's total fuel consumed is equal to the real fuel consumed from tank (take real fuel consumed from next full tank fill). This way you'll see if hobdrive calculates correctly.
Добавлено: 31 июл 2012, 18:57
kelloggs
hi again
yes the maths works out one imperial one us gallons. Well, i'm mystified now. I've watched the average mpg figure rise and rise to 40+ mpg while driving. If I change back to the non-beta build then i get 19 mpg or so which is what I would expect from this car. I'll have a good look at the set up to see if i've managed to get the wrong tag input to the display somehow. The last tank fill worked out at 18 mpg after a few "faster" runs. ;) Something is not right but I can't quite see it.
Добавлено: 01 авг 2012, 06:37
nonbeta supports only us mpg. try switching to us units in beta and see the numbers.
Compare the vehicle settings, probably some difference makes this.
Добавлено: 01 авг 2012, 11:53
kelloggs
i had the settings on l/100km and converted to imperial gallons 14.8 l/100km = @ 19 mpg or @ 16 us mpg
I'll do some more comparisons and check where the data is being picked up from. It's odd as occasionally the reading will change to a long decimal string half way across the screen then change back after a minute or so. It also seems to accumulate, the longer the drive the higher the mpg figure gets. It starts up at 0 then jumps to @20+ then slowly moves up to 30+. good thing is my wife sees the higher mpg and thinks the car isn't so thirsty after all :) sorry to keep posting but I'm only trying to help troubleshoot as I think you've done a fantastic job on this software and it deserves to get better and more well known.
Добавлено: 11 ноя 2012, 08:27
hobdrive beta 1.1.55
Добавлено: 28 авг 2013, 11:14
