I'm using the HobD program on a windows mobile device and have a Peugeot 107 (which is the same as the other cars in the title) but I can't find a specific setup in the vehicle settings.
Is there a standard setup that I should use or can anyone advise me on any specifics?
you may try toyota ECU in settings - but from what I read thats a european brand with toyota label, so most probably you only have to use standard default setup. Just configure fuel economy scaling if it seems to be wrong by default.
HobDrive(свежак) + Android4 rk3188 2din + Elm327USB + Pontiac Vibe 2003 Не пишите пожалуйста вопросы в личку. Создавайте тему в соответствующем форуме.
