Setup for Peugeot 107/Toyota Aygo/ Citroen C1
t_a_burton
Сообщение t_a_burton »
I'm using the HobD program on a windows mobile device and have a Peugeot 107 (which is the same as the other cars in the title) but I can't find a specific setup in the vehicle settings.
Is there a standard setup that I should use or can anyone advise me on any specifics?
Many thanks. :)
Re: Setup for Peugeot 107/Toyota Aygo/ Citroen C1
Hi,
you may try toyota ECU in settings - but from what I read thats a european brand with toyota label, so most probably you only have to use standard default setup. Just configure fuel economy scaling if it seems to be wrong by default.
t_a_burton
Thanks.
It's a Toyata inside, as far as I'm aware. I'll see what settings work best.
